NI TestStand
Why will the LabVIEW executable application not minimize when calling from TestStand?
I build an executable appliction of a LabVIEW VI, tried to call it from TestStand, and I setup the Initial Window State as "Show minimized, Activated", but when I run the sequence, the application still pops up. I tried with other windows application, they are fine. Anyone know what the problem is? Cheers.
(3,625 Views)
Hi - what versions of TestStand and LabVIEW are you using? Also, what operating system are you working with?
John M
(3,595 Views)
LabVIEW 8.5
TestStand 4.0
OS: Windows XP SP3
(3,589 Views)
I got the same behavior when I wrote an LV executable and called it from TS 4.0. None of the settings for Initial Window State seemed to change anything... I finally had to modify the properties of the actual VI being called by TestStand.
Add a property node to your main VI.
VI: FP.State  ( set this to Minimized ) as the first operation in the VI.  Rebuild into executable.
The call from TestStand to the executable will popup the window for a split second and then minimize it.  That is the best I can do right now!
PH
(3,569 Views)
Hi - I just tried this as well, and with the default settings, I agree that the Window State selection in TestStand is not affecting the LabVIEW executable. I will look into this a bit further, but in the meantime Teds suggestion is certainly a good workaround.
John M
(3,565 Views)
Yes, this is how I solved the problem for now, I have to add the window state in LabVIEW level instead of TestStand level. Thanks.
(3,563 Views)
