NI TestStand
Will saving a sequence file with modified variables work on all licensing levels of TestStand?
I am thinking of enabling editing of test limits for a few steps via an operator interface mechanism of some sort (popup dialog box, etc.).
If I make an API call to save the sequence file with the modified limits (as opposed to using the property export/import mechanism), will the call succeed if the end-customer has only a deployment license (no debug or dev)?
For that matter, if I *were* to use the property export mechanism via an API call from the operator interface, would that call succeed regardless of the licensing level on the target machine?
Thanks in advance...
(2,741 Views)
The deployment license will not allow you to save sequence files using the API.  It will generate an error.
Allen P.
NI
(2,737 Views)
