NI TestStand
Windows 10 IOT Enterprise
I know that recent versions of LabVIEW can be installed on Windows 10 IOT Enterprise. According to the NI website, it appears that TestStand is not compatible with Windows 10 IOT Enterprise, but I am not sure.
I have two PXIe-8821 CPU modules that came from NI with Windows 10. I installed LabVIEW 2020 and TestStand 2019 onto both computers. The hard drive of one quit working, so I replaced the hard drive. That machine has a Windows Product Key that states "Windows 10 IoT Ent". The computer activated as Windows 10 IOT Enterprise.
The other chassis has a PXIe-8821 that boots to Windows 10 Enterprise.
I see on the NI website that, starting in 2019, all PXIe CPU modules ship with Windows 10 IoT Enterprise.
Is TestStand 2019 compatible with Windows 10 IOT Enterprise? If so, is there a trick to installing it?
(1,686 Views)
     We have several industrial computers based on Win10 IOT Enterprise system installed with Teststand2017, 2019 , and 2021, which can run normally for a long time. So far, we haven't seen any compatibility problems.
But I didn't test labview because I didn't use it very much.
For your reference.
(1,465 Views)
To my knowledge, NI software supports all Windows editions of the same version.
Does LabVIEW Run-Time Engine Supports Windows 10 IoT Operating System?
https://tmesystems.net/
(1,460 Views)
