NI TestStand
Windows XP 64 bit
Does anybody have experience running TestStand on 64-bit Windows XP?
I know, it is not officially supported and as far as I know, all 64-bit support goes in the direction of Windows Vista (which, frankly, does not interest anyone here. The mood seems to be: stick with XP until Windows 7 is around), but perhaps someone tried it anyway on 64-bit XP.
Regards
Peter
(4,525 Views)
TestStand should generally run ok as a 32-bit program on 64-bit windows xp, however it will not be able to directly call into 64-bit code. Also you might want to verify that there are 64-bit XP versions of whatever drivers you require.
-Doug
(4,512 Views)
Thanks a lot. Yes, the driver issue is clear.
Peter
(4,480 Views)
Have to return to that message once again to clarify something in my mind. What exactly does "directly call into 64-bit code" mean? What will I be able to call from the 32-bit-TestStand on a 64-bit-machine?
I assume that calls into 32-bit DLLs, ActiveXs and .NET assemblies are fine. I guess that executable calls running 64-bit executables will also be OK. What about calls into 64-bit-compiled DLLs and .NET assemblies?
Regards
Peter
(4,160 Views)
You will not be able to directly call 64-bit dlls and .NET assemblies that require being used as 64-bit (dotnet code can be set to use "Any CPU" so when called from 32-bit code it's 32-bit and 64-bit code it's 64-bit). You can call 64-bit COM servers (at least with TestStand 4.2) if they are external process exe servers or if you use a surrogate process if they are .dll servers.
Hope this helps,
-Doug
(4,156 Views)
Yes, that helps a lot.
Peter
(4,152 Views)
