NI TestStand
Windows XP 64 bit
Hi Doug,
great to hear that.
I discussed your questions with the colleagues from our other image processing groups and we came to the following answers:
  1. What requirements of your application require use of 64-bit code?
    •   large data sets (processing of images of 128 MByte and up) with complex, memory-intensive algorithms
    •   massive multithreading (24 threads and up processing data sets and parts thereof in parallel) to reach cycle time
  2. What type of 64-bit code modules are you looking to call through TestStand?
    •   native DLLs and script engines
    •   .NET assemblies
  3. Is there a set timeframe where you will absolutely need a 64-bit version of TestStand?
    •   It is hard to give a fixed data; we will certainly be able to work for some time with our current solution of a 64-bit COM-Server, but this solution restricts us currently to a single image processing library which we built the server for (we want to avoid building additional or more generic such servers). However, I estimate that with the start of 2014 the restrictions will begin to be painful.
    Of course, I am aware that the actual TestStand Engine is the same in all hosts (SeqEdit, OI, REngine) but in terms of development sequence, it may be interesting for you that having a 64-bit Remote Engine would be more urgent for us than a 64-bit SequenceEditor as we built our environment such that we can and often do move expensive algorithms from the controlling TestStand process into an REngine.
Best regards
Peter
Message 31 of 32
(970 Views)
Thanks for the info, Peter.
-Doug
Message 32 of 32
(959 Views)
