NI TestStand
With TestStand 3.0, there are new UI controls (activeX). How do you get shortcut keys to respond to them using CVI?
The new ActiveX UI controls that come with TestStand 3.0 have a diffrent control panel in LabWindows 7.0 as compared with the non-ActiveX controls. The non-ActiveX controls have a shortcut key box so that a modifier keyboard key can activate the control. Does anybody out there know of a way to do this with the new TestStand 3.0 AxtiveX controls?
(2,936 Views)
Because of difficulties in supporting shortcut keys in certain development environments, this feature was not included in 3.0. I would expect to see it in a future version of TestStand.
In the meantime, you could:
a) Create a menu item that is bound to the same command as the button. The menu item will handle the shortcut key.
b) Look for the missing shortcut keys yourself via CVI callbacks or underlying winprocs.
c) Use a CVI button. You can still use the corresponding Command object to implement the command, determine its label, etc.
(2,936 Views)
