NI TestStand
Write to TestStand DataBase
Hi guys!
I'm using test stand and saving all data into the standar Database (access),
but I have others testers than I'm using just LabView (no TestStand Installed) and I would like save all test data into the TestStand dataBase, is any way to do that?
I'm not a DataBase expert, I just have basic knowledge, but I did a DataBase query some months ago, you can find find it here
https://forums.ni.com/t5/NI-TestStand/TestStand-DataBase-Query/m-p/2866064
do any body make the oposite? save all data into TestStand Database using SQL commands?
Thank you.
knowledge
(5,323 Views)
Hi LuisMontoya,
In case you haven't already seen these, here are some relevant tutorials and documents:
Getting Started Logging to Databases Quickly with NI TestStand
Logging TestStand Results to a MySQL Database
Database Viewer Application
If you don't have TestStand Installed on a computer, you won't be able to save data into the TestStand dataBase. However, you can use one of the database connectivity systems that TestStand communicates with like Oracle, SQL Server, MySQL, or a Microsoft Access database.
Regarding the opposite, this tutorial might be relevant:
Creating a TestStand Database Schema from Scratch
Shalini M.
Partner Development Engineer
Alliance Partner Network
(5,288 Views)
Thank you Shalumdawg,
but yes I saw that links already but have no information about what I need to do.
I need something like this:
insert into UUT_RESULT ("PartNumber"....... )
values (" "," ",......)
the way as TestStand is sending all data into database.
(5,279 Views)
Did you see  <TestStand Installation Directory>/Components/Models/TeststandModels/Database ? This might give you some ideas. how Teststand does the database access.
(5,265 Views)
Yes I did Mkossman,
there are "Schemas" to get results only, NOT to insert test results.
but thank you, I will continue trying.
(5,242 Views)
