NI TestStand
Writing Variables by using their Name from another string
Hey guys,
I just started to use TestStand and I have got the following question:
I have 2 fileglobals:
FileGlobals.Limit1 and FileGlobals.Limit2
The User will define the fileglobals in an INI File and the names and values from the files will first be stored in 2 Arrays.
Array of string: FileGlobals.ArrayNames  (Element 0 is "Limit1" and Element 1 is "Limit2")
Array of number: FileGlobals.ArrayValue (Element 0 contains value of "Limit1" and Element 1 contains value of "Limit2")
In one step I check if the name in the array is a fileglobals: In other words: Does FileGlobals.Limit1 and FileGlobals.Limit2 really exist.
PropertyExists("FileGlobals.ArrayNames[0]") and PropertyExists("FileGlobals.ArrayNames[1]")
Now I know that the Globals exist. the next step is saving the values of the Array (FileGlobals.ArrayValue) in the FileGlobals Limit1 and Limit2.
Is there a possibility to avoid the following:
Fileglobals.Limit1 = FileGlobals.ArrayValue[0]
I would like to use something like this:
FileGlobals."FileGlobals.ArrayNames[0]" = FileGlobals.ArrayValue[0]
I know that the Fileglobal really exists and I know the name of it. This would make later changes in variable names more easier in this case...
I hope you know what I mean and you can help me.
Thanks a lot!
Walter
(5,624 Views)
Hi Walter,
That is possible. Just use following Expression:
FileGlobals.SetValNumber(FileGlobals.ArrayNames[0],0,FileGlobals.ArrayValue[0])
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,608 Views)
You can also use the Evaluate() function to get the reference of your variable.
This function is a little bit magic because if write some thing like this :  "Evaluate(FileGlobals.ArrayNames[0]) = FileGlobals.ArrayValue[0]" it will directly write ArrayValue[0] into the variable described by FileGlobals.ArrayNames[0].
To have this working you just have to ensure that 'FileGlobals.ArrayNames[0]' contains the whole variable name (lookup string): for example "Locals.MyValue" is correct ; "MyValue" alone is not !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(5,562 Views)
Hello Juergen,
thanks for your answer.
Could you save the example for TestStand 2010?
Walter
(5,534 Views)
Hi Walter,
Here you are
Regards
Juergen
--Signature--
(5,523 Views)
