NI TestStand
Writing to mdb file with a base install deployment
Is there anything special I need to do to have TS write to a database file in a built application deployment?  I have set the results processing to do so on my development machine, but when I deploy the application to another system, it does not write to the file.  However, if I deploy the app to a system with Test Stand full development installed, it does work.  TIA
(1,924 Views)
Can you access that .mdb file with the MS Access installation on the target  system ?
(1,876 Views)
