NI TestStand
XML Report Flag definitions
I am using TestStand 4.2.1 to generate an XML output file, which I have to parse with some other application.  In those files, I notice that each of the Property nodes ends with a "Flags=" value such as: <Prop name='Status' Type='String' Flags='0x400000'>
I was wondering where the flags are defined?  (ie, what are the bit values?)
Thanks for any pointers,
Richard
(3,147 Views)
I hate it when you figure it out *after* you post!
MainSequence-properties-advanced.
Sorry for the QRM 😉
(3,146 Views)
The full list of flags, including their values, is documented in the NI TestStand Help.
http://zone.ni.com/reference/en-XX/help/370052J-01/tsapiref/reftopics/propertyflags/
Tom
TestStand Documentation
(3,126 Views)
