NI TestStand
XML report display in TestStand 4.0
I've just migrated from TS 3.5 to 4.0.  4.0 is more user friendly than 3.5.  But I can't display my XML report after running sequences.  If I choose other report format, everything is fine; if XML is set, the report file would be generated but I can't see it at sequence editor.   I forgot what I did because at the very beginning, the XML report was OK.  I posted my report configuration below and plz take a look.
Thank you
Message 1 of 1
(2,849 Views)
