NI TestStand
a limitation in number of items at toolsmemu,.ini ?
I'm using Testand customized Tools menu in order to let operators at production line to load test programs easily. The problem is that after number of items I added I got the menu item 'Test uut' instead of the item I entered.
I attached file s which I hope will clarify the problem.
I'm using Testand 3.5.
Ofer
(3,659 Views)
Hi Ofer,
I was able to reproduce the behavior using your ToolMenu.ini in TestStand 3.5. This seems to be a bug in TestStand 3.5. This bug has been fixed in TestStand 4.0.1f1.
Manooch H.
(3,602 Views)
Thanks a lot. Any patch for Testand 3.5 ?
Ofer
(3,596 Views)
Ofer,
TestStand 3.5 has a limit of 64 Tools Menu Items. TestStand 4.0 and later allow for 512+ Tools Menu Items. There isn't a patch for TestStand 3.5 however, there are many possible ways to workaround this limitation. For example, you could have one tool that launches a code module user interface in which you can display as many tools as you want and then execute the necessary tool based on the user selection on the user interface.
Manooch H.
(3,553 Views)
Thanks a lot
Ofer
(3,531 Views)
