NI TestStand
access and set serial number on batch model from code
hi,
i tried to access : RunState.Root.Locals.ModelData.TestSockets[0].UUT.SerialNumber
from my c# code , using :
seqcontext.Root.Locals.SetValString("ModelData.TestSockets[0].UUT.SerialNumber", 0, ProductSerialNumber);
also :
seqcontext.Root.Locals.SetValString("RunState.Parameters.ModelData.TestSockets[0].UUT.SerialNumber", 0, ProductSerialNumber);
both didnt work
please advise how can i set the sn from my code instead of prebatch model mechanism
thanks
(2,853 Views)
What version of Teststand are you using? Are you programming in Teststand or Visual Studio or another environment?
Chase
NI Technical Support Engineer
(2,809 Views)
programming using visual studio c#
i solved this.
now i face something else - _ExecutionViewMgrEvents_EndExecutionEvent is not envoked at the end of the batch run
i handle the c# code according to this event which tells me that run is over ( on single uut it works perfect)
how can i envoke it from teststand?
(2,807 Views)
