NI TestStand
action parameter checks
I created an action step in TestStand  4.0 which calls a function in a DLL created in LabWindows/CVI 8.1. It was working fine, but I made a change to the DLL function which added an additional parameter. I re-compiled the DLL, but forgot to go into "Specify Module" in TS for this step, before I ran the sequence. To my surprise, I received no errors or failures - TS just skipped executing this step! When I realized what happened and did a "Specify Module" , TS correctly showed me the function call parameter list had changed. All works well again after I updated the function call
Is there a setting that I am missing? I would like such an error to be flagged. The step is marked "Do not record results"
Don Frevele
(2,883 Views)
Don,
your question seems to me to be connected to this.
The solution, of course, does not fit to your question, but it has the same reason (in my opinion).
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,870 Views)
