NI TestStand
add treeview in Teststand sequence
To make the program code in TestStand little clearer, it would be very helpful if you could own "treeview" Insert.
Would be possible to implement something or is there something like this?
The functionality would be best if this were performed exactly as it is already at the "Setup, Main and Cleanup" implemented. Only that you can place these "treeview" where you like.
(3,425 Views)
Andreas,
you should post this in the TestStand Idea Exchange forum. Here is already the requested suggestion.
Norbert
Norbert
Expert: Geometry
(3,415 Views)
Please describe your use case in more detail. There is already a feature to display a graph of the sequence call hierarchy, and you can quickly navigate between sequences by double-clicking on sequence calls and using the back/forward navigation buttons. Please explain the use case that you think would be better addressed with a showing a full tree in the step list view.
-Doug
(3,404 Views)
