NI TestStand
adding TS commands to toolbar in OI
is it possible to add TS commands to a toolbar of a CVI written OI similar to TS_InsertCommandsInMenu?
Thanks in advance for support.
Regards
Steffen Schmdit
(2,877 Views)
Currently, there are no environment specific helper functions for putting commands in toolbars. However, you can still easily execute commands from toolbar buttons your create.
To get a command object, call  <ManagerControl>.GetCommand.  The command object has methods to execute the command, determine if it is enabled, etc.
(2,865 Views)
