NI TestStand
adding a variable in a Message Popup
Hi guys, how to get a local variable in a message Popup? I try "string text"+ Runstate.Caller.Locals.foo ... Coz runstate is while program is running, Caller is the calling step and then local variable.
But this give an error. Where to access my local variables while running?
(8,612 Views)
First of all, it depends on the data type of the variable. String can be added "similar" to the way you described. Numeric and boolean has to be cast.
Second, you seem to misunderstand the concept of the RunState-property. If you want to insert a local variable of the sequence you are currently running, the expression should be:
"My Dialog Text " + Locals.<localname>
Don't forget type casts if not working with string variables!
hope this helps,
Norbert
Norbert
Expert: Geometry
(8,610 Views)
Norbert, how I do this typecast?
(8,608 Views)
Use the function Str()
eg
"The value is " + Str(Locals.Reading, "%d") where Locals.Reading is a Numeric
Regards
Ray Farmer
(8,596 Views)
Just to clarify, RunState.Caller is the caller of the -sequence- you're in, not the caller of the Message Popup. The help file has pretty good explanations for the majority of the RunState sub-properties.
(8,582 Views)
