NI TestStand
adding the tabs for step setting of custom step
I have created a custom step. In that i need to add a tab for the data source as in the numeric limit test... How to add that tab?
Alagar
(3,347 Views)
I need to add the tab for data source in the step setting for that custom step...
(3,344 Views)
It really depends on what language you have used to create the custom sub step edit dialog function.
If its C, then have a look at the default code for the Numeric Limit Step Type (EditNumericMeasurementStepNoStatusExpr() in CommonSubSteps.dll).
Regards
Ray Farmer
Regards
Ray Farmer
(3,337 Views)
Thanks Ray
(3,334 Views)
