NI TestStand
additional results
 My Labview funtion returns a boolean pass/fail, as well as a serial number.
I use the pass fail with a TestStand PassFail step, which is fine.
However, I would like to record the serial number too. I tried the additonal result property, but
not having much luck.
What am I doing wrong here?
(4,297 Views)
  picture attached
(4,295 Views)
morngoose,
You must assign it to a variable.  I noticed there was nothing under your Value to Log column.  So on the Module tab you have to assign that Indicator to a TS variable.  It can be a Local, File or Global but TS basically has to log it somewhere.
That should do the trick.......or at least it worked for me.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,284 Views)
Accepted by topic author morngoose
Hi morngoose,
see attached example.
regards
ray
Regards
Ray Farmer
(4,274 Views)
