NI TestStand
api call to verify an expression
Is there any api call to verify (validate) an expression that I can use in CVI? Similar to the check button on the left side of the textbox when entering an expression.
Thanks for the help.
--Aaron.
(3,703 Views)
Engine.CheckExpression and Engine.CheckExprSyntax
(in CVI TS_EngineCheckExpression and TS_EngineCheckExprSyntax).
Allen P.
NI
(3,696 Views)
Aaron,
You can use either:
or
Expression.Validate
In CVI you will use the Engine method as follows:
int __declspec(dllexport) __stdcall MyEntryPoint (CAObjHandle context)
CAObjHandle                 tsEngine = 0;
char* expression =0;
char * errDesc =0;
long startPos;
long endPos;
VBOOL isValid = VFALSE;
TS_SeqContextGetEngine(context, &errorInfo, &tsEngine);
TS_EngineCheckExpression (tsEngine, &errorInfo, context, expression, &errDesc, &startPos,&endPos, &isValid);
CA_DiscardObjHandle(tsEngine);
CA_FreeMemory(errDesc);
Check the TestStand API online help for more information.
Hope it helps.
Antonio.
Message Edited by Antonio Lie (NI) on 10-25-2005 04:28 PM
(3,694 Views)
Thanks a lot guys!
--Aaron.
(3,690 Views)
