NI TestStand
array in TestStand
Hi  gurus,
       I have a doubt that how can we create Array of string in TestStand 4.0 using C#.NET environment.
I used following method, but failed to create array:
objPropertyObj.SetValStringByOffset(10,PropertyOptions.PropOption_InsertIfMissing,"SRU"); // exception here....
The other following method creates array with empty size:
objPropertyObj.NewSubProperty(
"SUBSTITUTE.SRU", PropertyValueTypes.PropValType_String, true, "Arrayw",10 );
Please let me know how to set the size of the array at second method.
Thank you,
regards
RKK
(3,741 Views)
I beleive the InsertIfMissing only supported by the SetVal method.
You can use the SetValVariant Method to set a complete array. look at the example snipet in the Help Programmer Reference and / or the example in the teststand folder.
Regards
Ray
Regards
Ray Farmer
(3,737 Views)
Also see PropertyObject.SetNumElements and PropertyObject.SetDimensions
(3,726 Views)
Hi rkk,
I have added a small function from a former thread to you
Just take a look at it
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,708 Views)
