NI TestStand
axTerminateRestartButton
How do you change the caption displayed on the axTerminateRestartButton? Where is this documented? I need to make changes to several user interface controls in TestStand 3.5.
Steve
(2,802 Views)
Hi Steve,
You should find it in the UIControlStrings file in the Language folder.
To override this, dont change the value in the NI\Language\English folder but add the Main Tag [TSUI_COMMANDS] and item EXECUTE_RESTART = "Res&tart" (with your changed value) in the
User\Language\English\CustomStrings.ini file.
Dont forget to Restart TestStand Operator Interface to see the changes.
Regards
Ray Farmer
Regards
Ray Farmer
(2,795 Views)
