NI TestStand
basic data logging information
I would like to setup a data acquisition system consisting of cFP-2020 module and the cFP-SG-140 module with connector block.
My software:
Labview 7.1 Developer Suite
Diadem 9.1 Advanced Edition
I planed to run the data logger on the cFP-2020 module. The data should be saved to the Compact Flash card of the cFP-2020 module.
I would like to record the signals of the 5 load cells plugged to the connector block.
I also want to access the 2020 module via internet explorer so the test engineers can see the signals during the test.
My questions:
1. How can I run a server on the 2020 module? Can I implement a front panel on this server, so I can start/configure datalogging via internet explorer?
2. Does anybody have training documentation how to write a datalogger for the module cFP-2020
Thank you for your support!!!!!
Johannes
(3,398 Views)
It may be best to re-post this in the LabVIEW or DIAdem boards
Regards
Ray Farmer
Regards
Ray Farmer
(3,389 Views)
hello johannes,
for using remotepanels on a RT target, see this knowledgebaseentry.
for datalogging there are examples shipped with labview, which should give you a starting point. (help -> find examples and type "datalogging" in the search field).
regards,
robert h
national instruments
Message Edited by RobertH on 08-16-2005 01:26 AM
(3,368 Views)
