NI TestStand
best practies TestStand application with RealTime target
i'm searching best way in order to manage these actions:
1. i have labview application that call TestStand sequences based on NI example Build Script.lvproj
2. TestStand sequences have to send commands to real time targets, PXI, compactRIO. commands must have data arguments
3. RealTime application has several DQMH modules, one of them has function to detect the command sent from TestStand sequence and send it to specific DQMH module. then DQMH execute specific command
which is the best way to manage the point 2? for example, i can develop sequence based on vi that send commands via networkstream or TCP. i would like to understand if there are documents that i can use as starting point/labview code or suggestion from communities to do it using the best practies
thank you for supporting me
best regards
Michele
thank you for the support
Best regards
Message 1 of 1
(456 Views)
