NI TestStand
[bug] In Custom Step Type properties TS2016
Hi
I got a huge crash when I make a custom step type and enter the properties.
If i chose the tab "Default Switching" TS crash with this Window(see attachment)
I use TS2016SP1
LV2017.0f2
both 32bit
regards Bjarne
(2,896 Views)
No one that can reproduce this?
/Bjarne
(2,861 Views)
Obviously, the issue is not simple to reproduce. A couple of questions:
1. What OS are you using?
2. Where do you define the new step type (SequenceFile, Type ini file)?
3. Do you create a new type from scratch or do you copy an existing one for modification?
3.a) If the latter one: Which is the original step type? Does TS crash in that type also?
4. Does it happen always/with any step type or only with a specific one?
4.a) If it happens only with a/some specific step type/s: What makes this/these unique?
5. Did you already perform a repair install or at least rerun the TS version selector?
6. Which user rights are you running in Windows/TS?
7. Do you have NI Switch and/or NI SwitchExecutive installed? If yes: Do they/Does it work properly?
Norbert
Expert: Geometry
(2,853 Views)
Hi
WIN8.1
Both
Any one of these
any
TS selector: Yes
Repair: No
Admin
Don't have NI switch
Regards Bjarne
(2,850 Views)
I assume that you have neither NI Switch nor NI Switch Executive (NISE) installed (you state only NI Switch). Default Switching uses NI Switch Executive.
I have to admit that TS shouldn't crash if NISE is NOT installed when clicking on that tab. However, you can double check by installing NISE.
Norbert
Expert: Geometry
(2,846 Views)
Accepted by topic author Briton
Hi
Just did an repair and now it NOT crashing!
Thanks for help
(2,844 Views)
