NI TestStand
bug with Response text box+Message Popup+image
Hello.
I use TestStand 2021 SP1.
In my test sequence, I have a Message Popup to ask the operator to enter numbers.
Operators have problems locating numbers on the board, so I added a picture in the Message Popup to indicate the place where numbers are written.
The first issue is not critical but surprising: the loading of the image is quite slow (several seconds). Making the picture size smaller does not improve the loading time.
The second issue is a blocking point: when a picture is loaded, the response text box becomes unresponsive. Before the image is loaded, it is possible to enter a few symbols.
My first guess was that something was wrong with the test stand installation or with my sequence.
But I tried this on a second machine with an empty test sequence and got the same result.
My question is, is it a bug in Test Stand or not?
(1,053 Views)
This is resolved in TestStand 2022 Q4.
Refer to "2041314" in the list of bugs fixed in TestStand 2022 Q4 at https://www.ni.com/en/support/documentation/bugs/23/teststand-2022-q4-bug-fixes.html
Thanks and regards,
(1,007 Views)
