NI TestStand
c#: Adding limits on Multiple Numeric Limits at runtime
Hello
I'm looking for a sample code on how to add limits to a Multiple Numeric Limits step at runtime from c#.
Depending of the DUT capabilities, not the same number of measurements are returned.
Best regards
Yannick Willener
(3,522 Views)
Are they returned in an array of numbers?  If so then you can just use the native step.  Just assign the returning array to Step.NumericArray and on the Data Source tab set up like the following:
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,494 Views)
Thanks. How to set the Name, Limits ant the Comparison Type for each measurement?
Best regards
Yannick Willener
(3,489 Views)
I'm not very good with C# but I created this example that does it explicitly in TestStand.  Maybe it can give you some pointers or get you headed in the right direction?
Let me know if you have any questions about it.  It is in TS 2010.
jigg
CTA, CLA
testeract.com
(3,476 Views)
