NI TestStand
calculating the mean
In my project iam continuously reading analog values from DAQ.I want to calculate the mean of these analog values for every 60 seconds or 120 seconds.any examples are welcome.
Thank u
(3,183 Views)
You posted to the TestStand board, but this problem would be better suited for Labview. In Labview, you could have a loop that reads the DAQ. In another loop, you could have a timer that waits the required time, then gets the DAQ values, add the values and divide by the number of values. The loop repeats and waits again until it is time to calculate the mean. See attached vi.
- tbob
Inventor of the WORM Global
(3,180 Views)
Thank u very much,It helped me.
(3,166 Views)
