NI TestStand
calling labview executable from teststand
Once I removed the Error In and Error Out, it worked.  The other parameters now show up correctly.  Thanks.
Message 11 of 17
(3,180 Views)
Teds, were you able to use any clusters with the DLL interface or is it probably a good general rule that they're off-limits?
Message 12 of 17
(3,174 Views)
Cluster and Boolean inputs do not appear to show up properly.  When you build the DLL in LabVIEW with a boolean and clusters, the Function Prototype ( with C Calling Conventions ) is:
LVBoolean *EnablePopUp + TD1 *errorInNoError
TestStand does not recognize either.
My solution was to use separate inputs for cluster elements and a numeric for the boolean.   Not the ideal solution but it works.
Asbo, I suppose you could try to add the parameters manually when mapping the cluster in TestStand.  Then you could try to select perhaps a 'C struct' for the Category and see if that works.
PH
Message 13 of 17
(3,169 Views)
I don't have any projects that require this interface right now, it was more a point of a curiosity.
Based on the linked documents below, it does sound like using a C struct could be a solution. I'll have to remember to play with this when I have some free time.
http://zone.ni.com/devzone/cda/tut/p/id/3936
http://www.docstoc.com/docs/31464530/Passing-Labview-Cluster-to-C-Structure-in-DLL
Message 14 of 17
(3,165 Views)
Is the DLL's ini file similar to that of the exe - can I add "
allowmultipleinstances=true
" to it to allow multiple instances?
Message 15 of 17
(3,154 Views)
In 2009, I see Calling System Exec.vi.  Is that the one you're referring to?
Message 16 of 17
(3,144 Views)
Attached is what I currently do, but as a VIT, I don't have control of various things like (in the EXE's .ini file)
allowmultipleinstances=true.
However, I need to use subpanels so that each instance of the EXE is on a separate tab.  I'm not sure how to do (with an EXE or DLL) what I now do with a VIT.
Message 17 of 17
(3,135 Views)
