NI TestStand
calling labview vi in teststand
Hello
Just started width teststand. But i immediatly have a problem when adding a labview vi.
Enclosed are 2 files which in my opinion are the same.
The first show the parameters list, the second which i created myself doesn't.
Parameter list is empty.
What do i wrong?
regards, Jan
(3,050 Views)
Hi Jan,
the problem rests by labview an is very simlpy. In 'MyPassFailTest.vi' you've forget to connect the Controls with the Connectors of the VI symbol. When you call this VI as SubVI in another VI, you can't see any parameters too.
I hope this help.
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(3,043 Views)
Hello Christian
Yes, that was problem. Forgot to tell that i also new to labview.
Thanks, Jan
(3,037 Views)
