NI TestStand
can read datas from *.xls file
I wanted to test the example "LoadFromExcelFile", which I have downloaded from the NI hompage.
when I want to execute the the sequence the error message in the attached *.jpg file occurs
what can be the reason for this?
thank you
kind regards
samuel
(3,043 Views)
The problem is <Locals> is not a valid name of the the sequence name nor is it a valid variable name.
You need to change the expression so that <Locals> is a proper lookup string for a variable such as "Locals.SeqName" where SeqName is a string in the Locals of your Sequence.
Or change the expression e.g. RunState.Sequence.Main["MainSequence "].Num = 6.6
Regards
Ray Farmer
Regards
Ray Farmer
(3,024 Views)
