NI TestStand
canceling uut info dialog at parallel model
Is it possible to cancel uut info dialog while working with parallel model? I want to use msg box input to enter product barcode. I want to generate a parallel testing sequence that will only ask for barcode entry to continue testing next board.
(4,490 Views)
Its possible using callbacks.What version of TestStand are you using?
(4,468 Views)
TS 2013. I'll appreciate if you can help me
(4,466 Views)
Check the attached sequence.
Hope this is what you were looking for.
(4,462 Views)
