NI TestStand
cant select class from .NET DLL
Hi All,
I am trying to create a .NET DLL to use in TestStand 4.1.1
Starting from a Class.cs file I found in the TestStand examples:
using System;
using System.Collections.Generic;
using System.Text;
using NationalInstruments.TestStand.Interop.API;    // TestStand Core API.  Add <TestStand>\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.API.dll to your project as a reference.
using System.Runtime.InteropServices;
namespace ClassLibrary
	public class Class
		public double CalculateAreaOfCircle(double radius)
			return System.Math.PI * System.Math.Pow(radius, 2);
 After running the command
csc /r:"C:\Program Files (x86)\National Instruments\TestStand 4.1.1\API\DotNet\Assemblies\CurrentVersion\NationalInstruments.TestStand.Interop.API.dll" -target:library Class.cs
I get a DLL file called Class.dll.
When I select this Dll in a TestStand action, there are no classes listed under the classes combobox. I allready provided an object reference variable.
What is going wrong?
(2,651 Views)
Accepted by topic author svh
In the meantime I found the problem: I was compiling my DLL to .NET Framework version 4.0, using "C:\Windows\Microsoft.NET\Framework64\v2.0.50727\csc.exe" made my DLL compile to v2.0 and now TestStand 4.1.1 can browse its contents.
(2,630 Views)
