NI TestStand
changing of video height and width in labview using a sine wave generate in simulink
In LABVIEW I made a program successfully that changes video height and width as the magnitude of sine wave changes at each point. But when I try to do this using NI SIT connection than it fails, i want to repeat above task using a sine wave genereating in simulink.
Many Thanks in advance.
(3,163 Views)
Try posting your question in the LabVIEW board you might have a better chance of it being answered
Regards
Ray Farmer
(3,157 Views)
How can I post my question to LABVIEW board?
Thanks for your reply and suggestion.
Best Regards
Muhammad Abul Hasan
(3,149 Views)
Same way you selected TestStand except you would pick LabVIEW from the dropdown 'Select Board' list.
(3,144 Views)
Select LabVIEW from the main web page (forums.ni.com) then press the New Message button.
Regards
Ray Farmer
(3,135 Views)
