Hi there.
Apologies if you have already answered a question similar to this, but I couldn't find one that was quite the same.
In my DLL, I want to pass in a string variable, and pass out another string. The actual data transfer is ok, but only after I have manually edited the prototypes, as in the "Specify Module" dialog for a C++ call it always seems to default to "Signed 8-bit Integer" from the "Numeric" category in the parameter details box for a "const char*" (where in fact I want "C String (const)" from the String category). For the output string I want "C String Buffer" from the "String" category but always seem to get "Signed 8-bit Integer" from the "Array of Numbers" category.
Can you tell me what I need to put i
n my IDL file to make it so that I don't have to manually change the prototype?
Peter Dawe
EADS Astrium.
