NI TestStand
check box for test execution in teststand
Can anyone help me in customizing Testand Fron End..?. If we have to execute multiple tests in any sequesnce, we have to select the tests and should hold <Control> button. Instead I want to please a check boxes so that i can select the check boxes for whichever test i want to run and execute them in on shot.
Please help me in doing this.
(3,146 Views)
Hi Dayanand,
Just to verify what you are looking for, you are wanting to open a sequence file in your User Interface that includes multiple sequences.  You want to display each sequence from this sequence file next to a checkbox on the User Interface.  The user can now select multiple checkboxes and when they select Test UUTs, TestStand will only run the sequences that have been checked.  Is this correct?
(3,123 Views)
