NI TestStand
check for a program
I wanted to create a flow where i can check for a program before continue on the next flow...can I know how would i do that? Thank you!
(2,972 Views)
You have to provide much more information for getting help.
What kind of "program"? Is it something on the PC running TS or is it something on your UUT? What is the interface?
How do you determine if the "program" is installed?
You see, those are the first questions comming into my mind within seconds after reading your post. There can be more, of course....
So please describe a little better what your task is.
thanks,
Norbert
Norbert
Expert: Geometry
(2,957 Views)
