NI TestStand
continous acquisition in PQA
HI all
I am using PQA through teststand wherein I am trying to continuously acquire videos from HDMI.
For PQA what i understood is we need to specify the number of frames which we want to process .
But in my case my frames size is not fixed i.e I want to acquire the video frames continuously and stored in buffer.
And I want to process that frames on my need.
Is there any way to acquire the frames continously in PQA irrespective of frame number .
Anyhelp would be appreciated.
(3,215 Views)
You can run the test over and over with number of frames captured as constant. Unfortunately there is no way (that I know of) where you can aquire variable number of images as the buffer size is a configured before you start aquiring images.
(3,201 Views)
