NI TestStand
copy LabView VI from on dev system to another dev system?
We have two development systems here.  I need a VI that is on the other system.  How do I get the VI from one development system to the other development system?  Do I need to deploy it?  Or can I just copy it?
Steve
(4,726 Views)
Accepted by topic author SteveFeeser
Just copy it over.  Make sure you have all of the subVIs that it might possibly call.
And if these systems are for the same thing, I recommend networking the two systems together and use a source control software (like SVN) to keep the codes in sync.
(4,721 Views)
The two systems are for different product lines.  They have different hardware in them and use PCs with different operating systems.
Steve
(4,719 Views)
You should still be using source code control.
(4,710 Views)
