NI TestStand
coupling requirement gateway word type with DOORs
Hello all:
     I'm using requirements gateway to acquire traceability information in word(.doc) with default word types, i can get the requirements information in RG, but when i try to export word to DOORs via RG, the requirements tag becomes a object heading, it should be requirement ID.
     Could anyone give a suggestion?
     thanks in advance!
(2,678 Views)
Are you using the Headings for requirements option?
https://www.linkedin.com/in/trentweaver
(2,627 Views)
Thanks for your reply, WW!
with this option, i can select the heading display or not, but could you also suggest 2 things, because i'm new for this and can't locate a exact forum to find help:
1 - how to put information in right attribute of Doors module? eg. i want "Requirement" in attribute "Object type" not in "Element type".
2 - How to export tables in word file without trash(took default word types in NIRG now)
thank you very much in advance
(2,620 Views)
