NI TestStand
create type paletts
I have now the problem, that all properties of the created step(steps created with CVI) which I add with "specify module" (double klick on the new created step in Type palett->Substeps->Specify Module  are not available when I add this step in my sequence. what is the problem here?
regards samuel
Message 1 of 10
(3,959 Views)
Have you created them at the sequencefile level or at Global level.?
If you load your sequencefile that was opened at the time you created your types, are they now available? If you are then you have created them at SequenceFile file level.
If you used the toolbar icon next to the StationGlobals icon then thats the global level and would be available to all sequencefiles.
If you use the View control on the SequenceFile window then thats the SequenceFile level and any type created at this level will only be available in the SequenceFile it was created.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 10
(3,957 Views)
Hello Ray,
please don´t misunderstand me. The new created step are available in all sequences , but the configurations which I have done in the "specify module" tab before I store the teststep are not available when use this teststep in a sequence
Message 3 of 10
(3,944 Views)
Is it possible to post your type palette ini file.
What version of teststand are you using?
Regards
Ray.
Regards
Ray Farmer
Message 4 of 10
(3,943 Views)
hello Ray,
here ist My Types.ini file
regards samuel
Message 5 of 10
(3,939 Views)
Ray,
I am using teststand 3.1
Message 6 of 10
(3,939 Views)
which of your step types is giving you problem?
Ray.
Regards
Ray Farmer
Message 7 of 10
(3,928 Views)
Hello Ray,
all my own created step types for example, "can_exit", "can_set_path", "can_send", "can_receive", "sort_spec", "sort_relay_list" and "return_burning_status"
regards samuel
Message 8 of 10
(3,922 Views)
Looking at your ini file, I couldn't find where you had specified your code module for any of your steptype.
Eg for "can_exit", I would have expected to find [can_exit.TS.SData] with modulePath = <to something>, funcName = <your function name> etc but there was nothing. All I could find was an EditSubStep, so there was no PostSubStep either.
Which is probably why you are having to specify it when you insert the steptype into your sequence.
You did specify a code module eiher via the Specify Module or as a PostSubStep when you were creating the StepType?
Also, once you have done this you can set the disable properties, "Can Speicify", so that when you insert the StepType, you dont get an active Specify Module menu item for the step.
Regard
Ray Farmer
Regards
Ray Farmer
Message 9 of 10
(3,908 Views)
Hello Ray,
Yes I specified the code modules eiher via the Specify Module when I were creating the StepType?
I think this behaviour is strange.
regards samuel
Message 10 of 10
(3,905 Views)
