NI TestStand
creating a table of default type
hi all,
I want to create .mdb files with different names but of defult NI define schema type.Is there a way to create them from TestStand?.
I just wanted to maintain the different UUT results in different mdb files.i am new to this feature of teststand and to database also.
can any one help me in this regard?.
Radha R
(2,982 Views)
Radhu,
You cannot create databases for logging in TestStand. TestStand only connects to existing databases to log its data. The following links should assist you in impletementing the logging. Rather than log to different databases you could log to different tables within the same database for each UUT.
http://www.ni.com/pdf/manuals/323435a.pdf (see chapter 6)
http://digital.ni.com/public.nsf/websearch/D30EC9BBA0D740C286256C760049DABD?OpenDocument
http://forums.ni.com/ni/board/message?board.id=330&message.id=601&requireLogin=False
http://digital.ni.com/public.nsf/websearch/D44A2FC939D893C386256D1A0078D013?OpenDocument
Test Engineer - CTA
(2,957 Views)
