NI TestStand
csv report
I'm after confirmation that the examples posted here for a CSV format report file in TestStand 3.1 will work with version 3.5 or if an example for the later version is available.
I'm being requested to generate the report in CSV as the production analysis tools the customer utilizes will accept only csv format data.
(5,931 Views)
did you forget to attach a file?
Regards
Ray Farmer
Regards
Ray Farmer
(5,928 Views)
I am new to Test Stand, and I am trying to ascertain if it is possible.  At this point in time no files exist.
An approach to achiving this requirement is the desired outcome here.
(5,915 Views)
I think Ray was asking about the example you mentioned. If there is an example on NI's site, you should provide at least a link to it.
(5,908 Views)
Sorry the link is http://forums.ni.com/ni/board/message?board.id=330&message.id=6104&query.id=35004#M6104 whic discusses the issue for version 3.1
(5,903 Views)
