NI TestStand
custom conditions
No it does not change.
Maybe you deleted/replaced that step.
Try with a new sequence.
But for your use case the previous step will work fine instead of the ID.
Message 11 of 17
(1,599 Views)
I was just curious...been away from teststand for about 2 yrs.  Your solution is MUCH better.  Thanks.
Message 12 of 17
(1,597 Views)
I think you are making a mistake going this route.  You should really use the SequenceFilePostStepFailure callback.  Your very case is the reason this callback is there.  You have the Step and Results passed in as parameters and you can write code to filter for certain steps.  Also, your code will be much more scalable by doing this.
Just my 2 cents but hey- it sounds like you have it working so good luck.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 13 of 17
(1,582 Views)
Thanks jigg.  Not being that profience in Teststand I hate over riding the callbacks.  I never know what else it'll affect.  If I do implement your suggest won't the popup occur every time a step fails because its in SequenceFilePostStepFailure callback?  I'll get the popup even if its another step where I DON'T want the popup...if the step fails
Thxs.
Message 14 of 17
(1,565 Views)
Do you know how you would use the same idea only if either of the 2 previous steps failed??
Step1 Test 1
Step 2 Test 2
Step 3 Popup if either Step OR Step 2 Failed
Message 15 of 17
(1,564 Views)
In the SequenceFilePostStepFailure you could precondition the popup step and put the names of the steps that will trigger it.  Then later you just simply add new step names.  So basically in the message popup step in the callback I would put in the precondition:
AnyOf(Parameters.Step.Name == "Foo",
Parameters.Step.Name == "Bar")
So using the callback method you will see the popup immediately after the step that failed.
In your case where you want both steps to execute and then do the popup you wouldn't want to use the callback.  You would just do it like you have with 3 steps but precondition Step 3 to use the results from Steps 1 and 2.  So something like this:
AnyOf(RunState.Sequence.Main["Step 1"].Result.Status == "Failed",
RunState.Sequence.Main["Step 2"].Result.Status ==  "Failed")
Regarding your comment about when to use callbacks.  It is hard at first but after a while you get a feel for it.  In general it is OK to override any callbacks available.  That is why they are there.  I answer these questions before I override a callback:
What is the default behavior?  How will overriding affect it?
Who is calling it and when does it get called?
What are the parameters?  This generally gives a clear indication of what it was intended for.
If it's a model callback then I read the comments for the sequence.
If it's an engine callback I look in the TestStand reference manual.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 16 of 17
(1,561 Views)
Thanks..
Message 17 of 17
(1,558 Views)
