NI TestStand
date/ time
First time poster. Our tester build department has been using NI equipment to measure and record voltage, current, time/ date, etc.... However, recently our resources that knew the most have recently retired. I pulled the log files and converted to Excel. The date/ format looks like this:
3756361947.500037
This is an unusable format as i need to be able to correlate the data with the correct time and date. Does anyone know how to covert this into a usable format? Much appreciated
(996 Views)
I just tried with LabVIEW Seconds to Date and Time and got the below response.
3:22:27.500 PM
1/12/2023
Let me know whether the date and time can be related with the logged data.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(937 Views)
