NI TestStand
dblog ordinal
Hello all,
I am having problems logging to a local DB, the following is the error description
MyModel Process Model Error: -9004
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred initializing a statement.
Schema: MySchema.
Item cannot be found in the collection corresponding to the requested name or ordinal.
Source: TSDBLog
Any clues of what does "requested name or ordinal" means?
(3,349 Views)
Hi << - N - >>,
That error usually occurs when you are requesting a field from the recordset that does not exist.
I'd check that you have spelt the field name correctly and that the field exists in the database.
Test Engineer - CTA
(3,330 Views)
Thanx, it turned to be the DB provider on my udl file...
(3,308 Views)
