NI TestStand
deal with teststand message popup
when I add a message popup in my sequence,I need two button: Ok(button1) and Cancel(Button2).and set timeout.
My question is like this; I need get the status when execute,if uesr click ok,the sequence should go to next step,the other stauts,the sequence should abort executing.
example:
Message Popup
if(RunState.Sequence.Main["Message Popup"].Button1Label=="OK")
   call sequence   //this action need execute when click "OK"
else
   break        //this is a action ,without any connection of message popup
end
but no matter what button I click ,the sequence always execute break,that's means the if condition can't get the status of message,where is my error.
any one help me ,thanks very much
(2,897 Views)
duplicate post see the following link
http://forums.ni.com/ni/board/message?board.id=330&message.id=21602&jump=true
Regards
Ray Farmer
(2,893 Views)
