NI TestStand
deal with teststand message popup
@LV_user1 wrote:
hi all
I have reopened a old thread again. I want to know is there any solution for the error coming at the edit time when we use the option suggested by Ray(error pops up when we try to run the sequence).Everytime i have click on "continue execution" in order to execute my sequence.
Are you referring to analyzer warnings?
You can disable warnings for a particular expression by using #NoValidation at the beginning of the expression (or with parenthesis around the part of the expression you don't want warnings for).
Hope this helps,
-Doug
Message 21 of 22
(1,118 Views)
Is there an option with Evaluate to use RunState.Sequence.Main["Message Popup"].Result.ButtonHit to return the string for the button that was clicked? I am using TestStand 2013.
Message 22 of 22
(1,067 Views)
