NI TestStand
debugging in Vs2005
Here i got some debugging Vs problem in Teststand.this is my first time to use Vs2005 in teststand environment.
when i assign the source code in the Edit .Net Call, there is an item named "source file contained Funcion",what should i configure here?
should i configure it as a class which contains the method called? (there is two class and one form in the source code)
Morever,when i make a breakpoint in the TS for the debugging step, when i step into the function(F8) ,there is an error appearing "class not registered", nevertheless, when there is no breakpoint ,it is running ok. what should be the problem?
Thanks a lot
Elvis
(3,509 Views)
You can find the definition of  "source file contained Funcion" in TestStand help:
  • Source File Containing Function—Contains the pathname of the source file. You must specify an existing source file. You can enter an absolute or relative pathname. Relative pathnames are relative to the TestStand search directory paths.
  • About the "class not registered" error, can you provide the exact error number? Maybe the following links are useful:
    http://digital.ni.com/public.nsf/websearch/A92CF6B69941B35D862568D900693DF5
    http://digital.ni.com/public.nsf/allkb/901B5E1C33A102A18625671C007C501F?OpenDocument
    (3,487 Views)
    Hi  Jessica,
    The debug problem has been almost solved . Anyhow, there are still some debug probem during debug process.
    The error message appears likes "Unkown Error from Vs debugging controller" without any error code.
    how could it be?can you provide some information about it? please refer to the attachment.
    Appreciate it for any information .
    Elvis
    (3,484 Views)
    Hey Elvis,
    Could you upload that attachment you were referring to?  Also, when do you get this error?  Is it when you try to step into all .NET steps or just a particular one?  I look forward to hearing back from you.
    Best Regards,
    Software Engineer
    Jett R
    (3,423 Views)
    hey JettR,
    Now the problem has been solved. however, i still appreciate your help deeply and keep focus on my issue.
    Elvis
    (3,404 Views)
