NI TestStand
debugging mainsequence
I have a mainsequence with several sequence call steps. Is it possible, in debugmode, to step into seq calls, without stepping into steps from the processmodel. In other words, in "Step into" mode I want to see only step from the seq call and nothing els.
(2,951 Views)
To SoftToon -
I believe what you are discussing is that if your process model defines a PreStep callback, TestStand 2.0 can step into these callbacks when you attempt to step into a code module such as a sequence call step. For TestStand 2.0, there is not a current workaround to prevent this behavior. We hope to prevent this behavior in a future release.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(2,951 Views)
